how to remove "the governor"
Old Jan 22, 2007 | 03:36 PM
jah19862003's Avatar
jah19862003 is an unknown quantity at this point
Default how to remove "the governor"
I own a 2000 blazer LT and it maxes out at around 98-99 mph is there any way to remove "the governor" so I can reach a faster top speed ??
Old Jan 22, 2007 | 11:01 PM
Dabber's Avatar
Dabber is an unknown quantity at this point
Default RE: how to remove "the governor"
Why would ya wanna??? In a blazer no less
Old Jan 23, 2007 | 05:41 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
I agree - I've hit the governor once, and I don't think it would be wise to go any faster. Governor is probably built into the ECU anyway - not a place where it's productive to start trying modifications.
Old Jan 23, 2007 | 06:05 PM
BLK85's Avatar
BLK85 is an unknown quantity at this point
Dont listen to them. Going fast is fun. I was going 155 in a 67 Camaro built to go fast(acctually just 400 hp 2.83 gears and I have no idea how the tires were). I have been fast in plenty of cars but I wouldnt go that fast in a Blazer, but the last person is right its built into the ECU. You could just buy one of those Hypertech programmers type things. Probaly around $300-400.
Old Jan 23, 2007 | 06:08 PM
94Blaze's Avatar
94Blaze is an unknown quantity at this point
you can buy my blazer, i have topped it out at 115 hahahaha
Old Jan 23, 2007 | 09:59 PM
Rammer's Avatar
Rammer is an unknown quantity at this point
The speed limiter is in the PCM's programming. Most are set to 96-98 MPH. PCM editing software/hardware or a performance programmer will allow you to modify this limit.
Here is a screen shot of my HPTuners, showing the limiter on a 2003 S10 4X4. It's kinda hard to read, but the stock limit is 98 MPH.
Old Jan 23, 2007 | 10:19 PM
^^^ Let me add to this. ^^^
Before doing something like increasing the speed limiter in your vehicle, you MUST make sure that your vehicle is safe enough to sustain speeds in excess of the limit. Not only must your vehicle be in tip top shape mechanically, but your tires MUST be of a higher speed rating than the speed you want to be going. Also, your tires must be at the appropriate pressure. If the speed rating is too low or the pressure is too low or too high, this could result in tread seperation, which at high speed is something to be avoided at all costs.
As always, keep it on the track. Recklessly exceeding the speed limit on public roads, either close to empty or completely deserted) will only get you or someone else hurt or worse, dead.
Old Jan 23, 2007 | 10:59 PM
Rammer's Avatar
AMEN to that, Kyle. These were NOT made to run at speeds higher than the limit or even near the limit, safely.
Old Jan 24, 2007 | 02:10 PM
pilgrim's Avatar
That's right. Remember, this is a vehicle with a high center of gravity and significant wind resistance. It was not made to go more than 100 MPH, and doing so on public roads with this vehicle is unsafe for you and for others.
I'm not trying to be preachy, I'm pointing out that speeds over 100 are outside the design limits of this vehicle in stock form, and therefore unwise.
Old Jan 24, 2007 | 03:08 PM
Dabber's Avatar
I'm not saying going fast ain't fun. I had my 99 Camaro up around the 210km point once.(Built for it) The blazer on the other hand I had up to about 150km once. It Rattled and shook so much I ain't gonna do it again(for safety sake) Again I am all for goin fast if the vehicle i'm in is meant for it.
