hypertech superchips jet chips. are they ok?
Old Nov 7, 2006 | 01:16 AM
2001blazer's Avatar
2001blazer is an unknown quantity at this point
Default hypertech superchips jet chips. are they ok?
hey guys im looking into a chip for my truck but im not sure if i want to do this i dont want it to hurt anything on my truck and i want to make sure its not a waste of money any feedback would be great thanks
Old Nov 7, 2006 | 01:27 AM
Default RE: hypertech superchips jet chips. are they ok?
Well, that all depends on what you want do happen... A hypertech tuner is a less restrictive tune than the factory programming and it is quick and easy to apply. I do believe there are other hand-held tuners that are also available, but you'd need to read reviews from people with your specific vehicle to get a grasp of which one is better.
There is always the option to have a custom PCM tune done, but unless you have a tuner close by, most require that you send in your stock PCM to have it modified.
And if you want to get hardcore and have some mods that require a tune to run properly, there is always the custom dyno tune where the tuner would modify the values to make max hp for YOUR engine and mods using a dyno to verify the changes and monitor the systems more closely to make sure that you won't have problems from the tune.
Old Nov 7, 2006 | 02:14 AM
Brian J. Lesko's Avatar
Brian J. Lesko is an unknown quantity at this point
My friend is a diesel mechanic for Ford. He said that a lot of the aftermarket chips available for diesel engines will shorten the life of the engines if not installed properly. A lot of them require mods to the exhaust and/or intake systems. You also may need to change oil and filters more often. I'm guessing that modifying a gasoline engine is not much different. You're just going to have to read up on the different products that are available.
Old Feb 21, 2007 | 03:01 PM
blazinblack's Avatar
blazinblack is an unknown quantity at this point
i have a 94 s10 blazer with the cpi motor and im looking for a chip i have headers and a k&n intake with a 180 thermostat and a obd1. what would be a chip thats most worth my money?
Old Feb 21, 2007 | 06:56 PM
drperry's Avatar
ORIGINAL: Brian J. Lesko
Tuning a diesel is a completely different can of worms...
I like my Hypertech Programmer III, it's given me more power (The engine doesn't lug in 5th gear @ 1000RPM anymore) and it seems like mileage has improved (probably because I can actually use 5th gear at 50km/h instead of 4th)
The nice thing about the Hypertech Programmer, is that some models offer tuning for 87 octane as well as 93 octane... It's nice to get a little better performace without having to spend the extra money on premium fuel...
danmiranda
May 14, 2009 06:00 AM
tjwiens91@hotmail.co
Oct 2, 2008 10:38 PM
99 Blazer 4 door
Performance & Brainstorming
Apr 23, 2008 05:16 PM
Stopphn
Apr 6, 2008 01:35 AM
2dr5spdblazer
Jul 2, 2006 02:33 PM
