in line 6 into a blazer??
Old Nov 29, 2006 | 12:03 PM
lorner's Avatar
lorner is an unknown quantity at this point
Default in line 6 into a blazer??
i have a 94 blazer that we use for snowmobile trail grooming, and the 4.3 is getting a little weak. has anyone ever put in a chev inline six cylinder motor in one of these trucks? is it tough to do, and how did it turn out? thanks. foodtown@sasktel.net
Old Nov 29, 2006 | 01:27 PM
Default RE: in line 6 into a blazer??
The problem with the newer I6 engines is their length and height. The I6 has 2 extra cylinders to add to its length and because the cylinders are vertical, the overall height of the engine is taller as well.
With that said, small block v8s have been swapped into the s-series platform many, many times with great results. Being a '94 and what I can assume is offroad use, you could do a carb'd v8 swap and have plenty of power.
If you are interested in a v8 swap, the place to check out is JagsThatRun.com. They quite literally wrote the book on s-series v8 swaps.
Old Dec 1, 2006 | 06:43 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
As a friend of mine says, the WHY question occurs to me. I'd suggest either fixing the V6 or going to a V8.
Old Dec 13, 2006 | 01:13 AM
lorner's Avatar
ok, i will scrap that one.now, how about installing a 4.3 from a 91 that is tbi, into my 94 blazer, which is also a 4.3 but mpi? any troubles with computers and such? thanks
kirkito
Dec 30, 2013 08:27 PM
Phillips8201
Mar 16, 2010 10:26 AM
poepoe624
Jan 10, 2010 11:48 AM
Boiler_81
Dec 2, 2008 10:04 AM
2klt
Mar 3, 2006 01:10 PM
