ls7 lifters in 4.3?
hmm thats is a good question, im gonna take a edemacated guess "lol", and im gonna say yes because most sbc internals are interchangable. like pistons main & rod bearings etc etc. ill see if i can find some specs on the 2 lifters to double check.
if you can use sbc and lt1 lifters in 4.3's then you should be able to use ls7 lifters. good for replacing stock ones, less chance of valve float at high rpm's, not like 4.3's rev very high. i believe the ls7 lifters are now stock replacements for lt1's.
+1 Why? Roller lifters = roller cam = different pushrods................IIRC
If it ain't broke, don't fix it.
Aaron
