Oh, the Seafoam question!
Old Feb 5, 2010 | 11:50 PM
panthersfan101's Avatar
panthersfan101 is on a distinguished road
Talking Oh, the Seafoam question!
so i have looked at EVERY seafoam post and can not find the answer i need!
if i ONLY do seafoam down the break booster line, will i need to change my oil? and is this even worth doing?
Old Feb 6, 2010 | 12:00 AM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
if you put seafoam down the booster line then it will get sucked back to the intake manifold and burned in the engine and out the exhaust, i dont see why you would have to change your oil because of that, i would change my oil just as regular matience not because of anything to do with the seafoam in the way you are using it. i know you can put it in the oil as a cleaner. so go for it.
Old Feb 6, 2010 | 12:06 AM
i think i might this weekend! want to clean it out and get the best sound out of my new glass pack
Old Feb 6, 2010 | 07:32 AM
The brake booster line is the same as pouring it down the throttle body. If you let the engine die off and allow the seafoam to loosen things up, you will need to change the oil afterwords. Just plan ahead and do the seafoam right before a regularly scheduled oil change.
Old Feb 6, 2010 | 07:46 AM
hubert hefner's Avatar
hubert hefner is on a distinguished road
it will smoke like crazy also so don't freak out when it starts smoking. I've used it in my oil before and ran it the lenth of the oil change and never had a problem. i usually put a quart of tranny fluid when i change my oil i also run that the life of the oil change.
Old Feb 9, 2010 | 12:24 PM
K5corey's Avatar
K5corey is on a distinguished road
i love using sea foam it seems to clean so much carbon build-up and yes it does smoke like crazy. I have heard that you should change your spark plugs after using sea foam but never heard anything about oil.
Old Feb 9, 2010 | 01:16 PM
04CVLXsport's Avatar
04CVLXsport is on a distinguished road
No you don't need to change your plugs, nor your oil, its like Nike, just do it, However if you do put some in the oil don't drive around on it long. no more than 200 miles. But don't take my word, I'm just a newbie.
mykeboy01
Jun 6, 2011 10:23 PM
cr8390
Dec 28, 2008 12:19 AM
dion21379
Mar 27, 2006 04:10 PM
tomsblazer
Feb 4, 2006 08:56 PM
khalid_20879
Jan 3, 2006 04:07 PM
