starting issues
Old Dec 14, 2009 | 02:37 PM
jakeclope's Avatar
jakeclope is on a distinguished road
Unhappy starting issues
I have a 99 blazer 2dr LS 4*4. It cranks over about 10 or so times when cold. Even does it in the summer. Replaced the spark plugs, wires, cap and rotor. Sometimes if I shut it off and run in to pay for gas or something quick and go to start it it will fire up right away, rpms go up and on the way down it will clunk out. Any ideas on this problem would be awsome.
Thanks, Jake
Old Dec 15, 2009 | 08:52 AM
terry s's Avatar
terry s is on a distinguished road
I suggest you check the fuel pressure. You should see 58-60 psi when you turn the ignition on before you start it. Also is the fuel filter due to be changed?
Old Dec 16, 2009 | 02:24 PM
jakeclope's Avatar
thought about the filter will try that next.. thanks
Old Dec 18, 2009 | 10:19 PM
bch5002's Avatar
bch5002 is on a distinguished road
If the filter is too clogged, you may need a fuel pump as well.. hopefully not though..
cgrett
Nov 15, 2010 09:08 PM
tadder52
Dec 18, 2009 09:38 PM
Sprocket
Mar 20, 2008 09:39 PM
dragonsdeath
Oct 7, 2006 01:08 AM
BuddaBoy
Engine & Internal
Dec 7, 2005 03:36 PM
