supercharger for old blazer
Old Feb 6, 2006 | 06:46 AM
psyco1887's Avatar
psyco1887 is an unknown quantity at this point
Default supercharger for old blazer
i have a 1992 and a 1994 s-10 blazer 4.3 engine. the 94 is a vortec and the 92 is the regular 4.3
and i can't find a supercharger or a turbocharcher for either.
i figured i could take one off a typhoon but i can't find one of them either.
anyone know a place?
Old Feb 7, 2006 | 12:14 AM
Bgray's Avatar
Bgray is an unknown quantity at this point
Default RE: supercharger for old blazer
Whipple use to make a huffer for the TBI 4.3...try them
Old Feb 7, 2006 | 12:49 AM
Pretty much anything forced induction would have to be custom. The easiest course would be to get a procharger (Centrifugal S/C) and just have custom mounting plates made up (or possibly use a mounting kit for a 350sb), but you'd need to go with their smallest unit and then you'd probably have to put on a larger pulley to make it turn slower due to the lower displacement.
The problem with both a turbo or CSC is that the bottom end should really be upgraded. At the very least, some 8.5:1 pistons should be tossed in to keep from getting very harmful detonation due to excessive pre-ignition cylinder temps. High temps can be over come with an intercooler for both cases, but the CSC may be able to run without an intercooler with lower compression pistons. The CSC would require less custom fab than the turbo (collector pipes, down tubes, intake piping, intercooler piping, etc).
Either option is a daunting task to say the least! Good luck!
Old Feb 7, 2006 | 03:20 AM
20Blazer00's Avatar
psyco1887:
Try Race Proven Motors at http://www.raceprovenmotors.com/inde...10ccd8b5e3ad10
The deal in Cyclone/Typhoon parts and machine work...
Maybe also try http://www.syty.net/forums//index.php?
Old Feb 8, 2006 | 04:01 AM
psyco1887's Avatar
i was already planning on upgrading to forged pistons.
but i am also having a little bit of trouble finding a vendor for the pistons too.
i can only find parts for imports.
and all the domestic websites i have seen have been in sets of 8 only.
Old Feb 8, 2006 | 06:11 PM
RedBlaze's Avatar
From: Atlantic, NC (eastside whats crack-a-lackin!)
RedBlaze is an unknown quantity at this point
Is the 94 a CPI?? if so they do not make any supercharges or turbocharges for that motor
Old Feb 9, 2006 | 03:14 AM
psyco1887's Avatar
the 94 is a central multi port fuel injected vortec
Old Feb 9, 2006 | 01:09 PM
RedBlaze's Avatar
Yeah I used to have one of those motors myself. They do not make a supercharger or turbocharger for that motor.
green dot
Nitrous, Super Chargers, & Turbos
Nov 16, 2012 02:34 PM
allterrainbadass
Sep 21, 2011 09:32 PM
mikepro
Aug 15, 2011 07:03 PM
kwikshifter
Jul 16, 2010 01:35 AM
Blaize70
19
Sep 20, 2008 10:23 AM
