swap a 2.8l for a 3.4l
Old Jun 24, 2009 | 01:56 AM
86blaze's Avatar
86blaze is on a distinguished road
Default swap a 2.8l for a 3.4l
I have heard that you can swap a 3.4l rwd out of a camero or firebird into a 1986 s-10 blazer. If it's true let me know and if you know exactly how much modifieing is needed.
Old Jun 24, 2009 | 02:33 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
it actually should be fairly straight forward the 3.4 is just a bored out 2.8 and the 3.4 is a factory replacement for the 2.8. it should be a direct replacement and the only modifications will be to the fuel system iirc. im sure someone with a little more knowledge will chime and be a little more in depth with the description.
**Edit, im not usually this knowledgeable on engine swapping subjects but youd be surprised at what a simple search will turn up
