Thanks Everyone!
Old Feb 25, 2007 | 03:14 PM
hoop85's Avatar
hoop85 is an unknown quantity at this point
Default Thanks Everyone!
I just wanted to tell you all that the threads I have read really gave me some good things to try and have worked so far. I.E. I have a '85 S-102.8L V-6that was having some idle and power issues off the line and by reading previous threads went out and bought AC/Delco Platnium plugs and a can of SeaFoam and it has already made a world of difference the truck was runnin Bosch Platniums before and by reading your posts I decided to switch back to Delco's I ran them in my K-5 and couldn't tell a differnce. As for the SeaFoam I had heard of it but never really tried it but WOW that stuff is cool the smoke show which only lasted a bit was cool and I followed the advice I had read on here about it. I ran it through my PVC an put some straight into the carb and into the crankcase and have noticed a performance increase I was a little nervous at first do to the may foul a plug and break up carbon holding seals closed but it worked great for me! Thanks toall of you and I'll definetly keep up on the topics. See ya around the Junkyards.
[IMG]local://upfiles/5576/E1F7611A4752428DBBC029240D8761A2.jpg[/IMG]
Old Feb 25, 2007 | 05:49 PM
BlazerMan85's Avatar
BlazerMan85 is an unknown quantity at this point
Default RE: Thanks Everyone!
I used Seafoam in 3 out of 4 of my Volvos. Does absolutely **** when you put it in the gas, but when you run it through the carb/intake, it's miracle stuff.
Now you just need to post picture sized pics, instead of thumbnails. :P PM me if you can't figure it out.
Old Feb 25, 2007 | 10:12 PM
Glad you found the answers you required!
With the seafoam in the oil, make sure you change the oil & filter between 200 & 400 miles.
For picture posting, please see the FAQ linked to in my signature.
gizwilly
Dec 4, 2006 07:28 PM
jagblazer01
Nov 24, 2006 12:38 AM
jun
Sep 20, 2006 10:43 AM
dashyman
Aug 14, 2006 05:18 PM
swartzy
Tires and Wheels
Feb 15, 2006 01:02 PM
