Tow flexible cables to throttle on 95 Blazer
Yes, one would be for your throttle and one would be for your cruise control.
As for how to adjust it, I'm not familiar with the 95s. However, I would suggest not adjusting anything on the throttle body. The idle should be controlled by the ECM instead. Is there a check engine light on? I think your vintage does not use OBD-II so I can't help with the code reading. Perhaps someone else can help with the diagnosis.
A Haynes manual might help if you have not already bought one for yourself.
mr.vls
Apr 13, 2013 08:20 PM
t.lyttle
May 24, 2009 01:37 PM
