throttle cable adjustment?
Old May 16, 2009 | 07:24 PM
t.lyttle's Avatar
t.lyttle is on a distinguished road
Default throttle cable adjustment?
i need to adjust my throttle cable im at about 80% thottle right now when i put it on the floor....any suggestions?
Old May 16, 2009 | 08:44 PM
I am not aware of any actual adjustment built into the cable. You could replace the throttle cable or you could try making some slit washers to put over the cable on the pedal end to space the cable. Get some small washers and cut one side with a pair of side cutters. Then squeeze them together so the ends are touching, but twist them slightly. This will give you a slight opening that you can get the cable into which you can bend back to make them stay on.
Old May 16, 2009 | 09:23 PM
oisinirish's Avatar
That works fine. i had to do that on my '80 stepside.
Old May 23, 2009 | 09:02 PM
t.lyttle's Avatar
thanks guys it worked i have 100% throttle now!!
Old May 24, 2009 | 01:37 PM
Good to hear!
natebocek
Aug 16, 2017 10:02 PM
Squad-6
Apr 22, 2013 02:19 PM
redneck44244
May 30, 2012 02:30 PM
bret
Feb 11, 2010 05:58 PM
ChrisAttebery
Jul 3, 2007 12:31 PM
