upgradig to Pertronix electronic ingnition II
Old Nov 9, 2008 | 05:43 PM
guillermoariast's Avatar
guillermoariast is an unknown quantity at this point
Default upgradig to Pertronix electronic ingnition II
Hi, i have 1980 chevrolet blazer k5, i would like to install a Pertronix Ignition II system, because i want more Hp and mileage.
Have you done something like this?
Would you please tell me your opinion?
thanks
Old Nov 9, 2008 | 06:51 PM
Default RE: upgradig to Pertronix electronic ingnition II
Your blazer should have an HEI distributor, not the older points style. As such, this module will not help. You can get a performance coil (I have an Accell Super Coil on the distributor I am planning on dropping into the motor in my K5) as well as an upgraded electronic ignition module for under the rotor, but that is pretty much it without going to a new distributor.
Old Nov 11, 2008 | 11:14 AM
Thanks for answering people, i think i have a special kind of distributor because i do not see a coil, it might be inside the distributor.
I would like to show you some pictures of my distributor so that you can tell me what kind is it and how can i improve in order to obtain more hp and better mileage.
I would like to find some trick that help me to save some fuel, because my truck has a low mileage, 12.5 miles per gallon.
Thanks
Old Nov 11, 2008 | 11:34 AM
That is an HEI distributor. The coil is mounted to the top of the distributor cap.
As far as saving fuel... That is a difficult one as you are driving a fullsize truck with an I6 engine that is not all that great on fuel to begin with...
Denman3266
Jul 10, 2010 04:21 PM
92blazer92
Jan 22, 2010 06:38 PM
davidh123
Jul 31, 2007 06:50 PM
SniperX13
Mar 13, 2006 06:13 PM
4WD Rookie
Mar 6, 2006 10:41 PM
