V8 swap: 383 or 5.3l Vortec?
Old Oct 8, 2009 | 09:59 PM
97blazer13's Avatar
97blazer13 is on a distinguished road
Default V8 swap: 383 or 5.3l Vortec?
I am currently working on my 1997 4 door 4wd blazer, which is currently sitting in the driveway with a broken suspension lift and a factory 4.3l v6 that is not in much better shape. I am thinking either a 383 or a 5.3l v8 to replace the stock engine. I know the 383 will drop right in, and the 5.3l will require a huge amount amount of custom parts. I was wondering if anyone had done either of these, and any help offered would be appreciated. I have some time before this project gets going, so deciding which motor to use is not a priority right now. Thanks in advance!
Old Oct 8, 2009 | 10:41 PM
CH@Dbee's Avatar
CH@Dbee is on a distinguished road
also look into the LQ4 aka 6.0L iron block LSx
Old Oct 9, 2009 | 01:58 AM
okvortec's Avatar
Xtremechubs is currently putting a 5.3 in his Blazer
Thread here. Lots of good info there.
Old Oct 9, 2009 | 04:35 PM
97blazer13's Avatar
I have seen that thread. Its an awesome project, but I hear tell that there are no motor mounts for 4wd. Great info on upgrading the airflow and the electrical work. If I go with the LS I am going to stick to the LM7 due to its relatively low cost. It really depends on whether or not I buy another car before the project. The 383 wold be easy to do in a weekend, but the LM7 would be more fun once finished, and would require a second vehicle while the Blazer is garaged.
Old Oct 29, 2009 | 11:59 PM
spooky's Avatar
spooky is on a distinguished road
I think its the same amount of work with a 350SB or a 5.3l. Electrical should be about the same. Think you still need to tear apart the dash to add a wire. Motor mounts need to be changed out for both. Both need computer flashed to v8. Seems the same, but havent really done a lot of research on sb350.
As far as no 4wd parts. Here is a link to your motor mounts and they have some other good stuff for the swaps.
http://www.s10v8.com/store/product_i...0ef261cfd697d2
Kilo
Aug 17, 2013 08:13 AM
irish7317
Apr 3, 2011 10:56 AM
84blazer383
Aug 24, 2010 11:04 AM
debo42
Sep 14, 2009 06:34 AM
96blkblazer
Feb 26, 2009 04:29 PM
