Vortech heads on a 1st Gen 4.3?
Old May 1, 2011 | 11:59 AM
JMorton's Avatar
JMorton is an unknown quantity at this point
Default Vortech heads on a 1st Gen 4.3?
What's involved? I've been told that the heads can be picked up cheap at the bone yard and will add 40 horse. true? electronics the same or different? Would like to give it a shot if it's not too involved.
Old May 1, 2011 | 12:35 PM
zr2dan's Avatar
zr2dan is on a distinguished road
im pretty sure the heads are direct bolt on but your gen 1 intake wont work with the vortec heads but i think edlebrock makes a intake you can slap a carb on that will match the heads
Old May 10, 2011 | 07:51 PM
chris015's Avatar
^^ what he said. and that intake is 300 bucks. If i were you,id go to a pull a part and get a WHOLE 5.7 350 in the same year as yours for 300 bucks,and do a v8 swap. if you have a 2wd,its easy as cake. wirings the same,trans mounts up. you just need swap mounts and efans.
Sisk
Lifting Tech
Feb 15, 2010 07:11 PM
NC93BLAZERLT
Nov 23, 2009 09:12 AM
old skool luvr
Nov 10, 2009 09:20 PM
94blueknight
Apr 6, 2008 08:34 PM
TripleBlackBlazer
Apr 3, 2008 06:48 PM
