Water temperature gauge?
Old Mar 13, 2008 | 07:59 PM
redlineracerjpcb's Avatar
redlineracerjpcb is an unknown quantity at this point
Default Water temperature gauge?
I was wondering where the water temperature sender is located on a 96 4.3L vortec. I checked other posts and searched for it but couldn't find anything....I am going to be drag racing it this summer and i want to put a new gauge in it with a much better swing on it and i was wondering where it is located and if its mechanical or electronic? Thanks!
Old Mar 13, 2008 | 11:08 PM
rriddle3's Avatar
Default RE: Water temperature gauge?
It's located on the front top of the engine right in front of the water outlet tube and it's an electrical sensor. To replace it, disconnect the negative battery cable, drain the coolant to a level below the sensor, unplug the connector and remove the sensor. Installation is the reverse.
[IMG]local://upfiles/4800/F04624D154504EDE8F411395DAADECD7.gif[/IMG]
Old Mar 16, 2008 | 12:35 PM
alright thanks that helps a lot!
2005Jimmy
Nov 21, 2018 01:33 PM
89GMCJames
Feb 23, 2011 01:08 PM
dobyken
Oct 22, 2010 07:16 AM
ashmarie321
Jul 13, 2010 01:15 AM
Ola Nordmann
Feb 1, 2006 06:56 PM
