Whats everyones running temp or the coolant/engine in the 4.3?
Old Aug 25, 2009 | 12:32 AM
  #21
Originally Posted by Katmandu
My 99 runs around 180 degrees.
It currently has NO heat inside. I'm trying to track down the problem right now.
180 is too low. But lets keep that discussion in your new thread pertaining to your specific problem.
Old Aug 25, 2009 | 01:01 AM
  #22
nervousmini's Avatar
nervousmini is on a distinguished road
I've been running @ 190 with a 195 tstat.
Old Aug 27, 2009 | 10:33 AM
  #23
jsmz's Avatar
Banned for childishly attempting to delete all his posts
jsmz is an unknown quantity at this point
what temp do you all think this is? too low?
my blaze has ran this temp since i got it. have a new therm, just havnt put it in.
Old Aug 27, 2009 | 02:34 PM
  #24
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
That pic is exactly what my blazer is running at.. it never goes higher than that.
Old Aug 27, 2009 | 03:13 PM
  #25
jsmz's Avatar
do you ever notice a pre ignition type rattle ?
Old Aug 27, 2009 | 03:27 PM
  #26
2002XTREME's Avatar
nope no noises..The strangest thing about the starting of my blazer is , when ya barely turn the key to start it it starts right up with no cranking almost..Maybe its the $180.00 battery i have in it from Sears...
Old Aug 27, 2009 | 05:01 PM
  #27
PaulO2288's Avatar
PaulO2288 is on a distinguished road
Well that pretty much where mine is too unless im sitting in traffic than it will go to 210 and stay there
Old Aug 28, 2009 | 01:10 PM
  #28
jsmz's Avatar
haha same here, i dont even hear my starter turn over. just barely tap the key.
im wondering if maybe my temp is the cause of my pre ignition rattle, ive done everything else to make it go away.
Old Sep 19, 2009 | 10:30 AM
  #29
Nvidia78's Avatar
Nvidia78 is on a distinguished road
I recently changed the thermostat in my blazer because i saw it was only running like 2 lines up from 100, thought maybe the spring was weak and opening too soon, I was getting 20 Mpg then, after I changed the thermostat and now its running right up at 195 I am pushing 24, so as stated above if your blazer is running too cool it will be in open loop all the time.. open loop is the default program in the computer in which to run, in that mode it does not rely on information from the sensors to adjust air fuel ratio, etc
Old Sep 20, 2009 | 09:30 PM
  #30
Duram98jimmy4x4's Avatar
Duram98jimmy4x4 is on a distinguished road
i will be gettin a new thormostat to add to the list of parts
