Whats everyones running temp or the coolant/engine in the 4.3?
Old Dec 9, 2009 | 02:42 AM
  #31
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
Originally Posted by jsmz
what temp do you all think this is? too low?
my blaze has ran this temp since i got it. have a new therm, just havnt put it in.
my truck reads this too. what do the little lines symbolize? i cant tell or figure out what the gauge is reading at? can you tell me? it never ever goes higher than this unless you drain the radiator while the truck is running....
Old Dec 9, 2009 | 03:27 AM
  #32
okvortec's Avatar
Ever since I rebuilt my radiator and flushed everything out, my truck runs at the 2nd large hash mark (the quarter tank mark if compared to the gas gauge). If I idle or sit in traffic for a while it will go up a couple dashes.
Old Dec 9, 2009 | 06:22 AM
  #33
MuddBunny84's Avatar
Banned
thats what mine sits at too kane.
Old Dec 9, 2009 | 12:29 PM
  #34
yeah but is that 150* or 160* degrees? i dont know what the temp is in degrees, thats what i want to know. and do the little lines represent increments of 5? or 10? like how do you read the darn thing? if you notice nobody has been able to read it. most of the time my gauge is one small line below the one thats pictures above..... i think maybe my thermostat has limited movement or its stuck open some what...can anyone help with this?
Old Dec 9, 2009 | 01:56 PM
  #35
okvortec's Avatar
Well, from the 100* to the 210* I count 8 dashes including the 210. So that means the 110* difference divided by 8 dashes would equal 13.75* increments.... which is a rather odd number.
Old Dec 9, 2009 | 11:21 PM
  #36
so i guess its impossible to read that guage pictured above... so no one knows what that temperature is.... man this stinks
Old Dec 9, 2009 | 11:28 PM
  #37
okvortec's Avatar
180-185 degrees.
Old Dec 10, 2009 | 07:29 AM
  #38
You would have to put a scan tool on to verify the ECT reading and "calibrate" how you read the gauge.
Originally Posted by okvortec
180-185 degrees.
I would say that would be pretty close.
Old Dec 10, 2009 | 10:42 AM
  #39
there is 1 slightly larger line between the 100* large mark and the 210* large mark, so what would that slightly larger line between the two larger lines indicate?
Old Dec 12, 2009 | 05:02 PM
  #40
ve3nsv's Avatar
ve3nsv is on a distinguished road
My 99 Jimmy was running just below a 1/4 way until I changed the thermostat. Now runs right where this picture is showing and gets there quite fast even in cold weather. I also removed the Dexcool and went back to the green stuff.
