Whats everyones running temp or the coolant/engine in the 4.3?
Old Oct 25, 2010 | 10:43 PM
  #81
69chevelle's Avatar
69chevelle is on a distinguished road
Originally Posted by bandidolenny
That's not hot enough for the computer to run the engine properly... you will get terrible gas mileage and there is no way it would ever pass an emission test. (not that alot of us have to worry about that)
my truck passed emissions and it runs around 140-160(too cold I know, have a new thermostat to put in) on normal days, or 210ish when its above 85 outside in the sun.(should have been a obd2 test but my system came up 'not ready' as I cleared my emissions codes as I pulled into the aircare center)
my truck also doesn't seem to really 'blow heat' untill around 140ish which takes a while to get to, sucks on the way to work at 5am.
Old Jul 10, 2011 | 05:29 AM
  #82
DaddysBlazer's Avatar
DaddysBlazer is an unknown quantity at this point
Both of my blazers run real close to two hundred degrees and ive been told thats normal for a chevy. I also live somewhere that stays above 95 degrees durring the summer.
Old Jul 10, 2011 | 10:46 AM
  #83
xgiovannix12's Avatar
190 to 200 ish thats tops
Old Jul 10, 2011 | 09:29 PM
  #84
chris015's Avatar
Im running about a 1.4 inch under the 210 mark on my 91. Im running the 180 thermostat. I may go back to the 205 or w.e. My gas mileage dropped a little after i changed it over.
Old Aug 12, 2011 | 01:36 AM
  #85
LioNiNoiL's Avatar
LioNiNoiL is on a distinguished road
I eyeballed the temp-gauge yesterday afternoon (106°F here in Vegas) and it sat steady at two marks below 210, which I reckon is about 182, and that was with the A/C running. I bought a new thermostat today to install this weekend, hoping to improve my 16mpg average.
Old Aug 13, 2011 | 08:50 PM
  #86
tskurja's Avatar
tskurja is on a distinguished road
Mine runs just under 210 at about 200. These engines need to see 200 degrees or the computer will not function properly. Your gas mileage will be in the hole and your cat will get clogged as well as others problems.
i agree i own 2 blazer and both run about 200 degrees and was told by a couple of mechanivs that is normal
Old Sep 1, 2011 | 01:36 AM
  #87
Manatee's Avatar
Manatee is on a distinguished road
Mine runs about 200. Today it was 108 outside temp, it ran about 200 going up I-17 to about 3000' while running the AC.
Old Jan 28, 2012 | 03:55 AM
  #88
blazinNdCHEVy's Avatar
blazinNdCHEVy is on a distinguished road
so whats the latest on this i have the same problem on my 93 w code, it didnt pass smog by high hc on high rpm, heater core bypassed, ran cold i replaced the t stat and now runs a little under the middle mark. i thought i failed due to not beeing in clossed loop but since my temp still looks slightly low i havnt smoged it again.
Old Jan 28, 2012 | 04:54 PM
  #89
tibby's Avatar
Default .
I think mine runs in the range of 190 to 200. I don't want to take any chances of it overheating with a thermostat with a higher temp setting.
jcw7897
Feb 6, 2015 06:23 AM
ab2008
Jul 10, 2012 05:16 PM
DoowBee
Oct 2, 2011 08:10 AM
zakm0n
Jan 9, 2011 07:31 PM
naf821
Aug 8, 2007 07:19 AM
