$900 I've spent in parts and I'm about to junk it!!! Help!!!
Old Apr 13, 2017 | 07:48 PM
Thelatchkeykid's Avatar
Thelatchkeykid is on a distinguished road
Default $900 I've spent in parts and I'm about to junk it!!! Help!!!
2004 and the head gasket blew, which took out the water pump with it. We've tore it all down, cleaned all valves, rockers, etc, replaced the gaskets, injectors, plugs and wires, mass air sensor, all other sensors around the plenum, vacuum lines. No cracks in the plastic intake or vacuum leaks anywhere. Mine has no EGR valve and didn't come with one from what I understand. Anyway, it's hard to start, idles hard, runs rich. Here's the kicker. When it's revved over 1,000 rpm, it runs smooth, no vibrations to be found. When the throttle is let back down, it wants to die out completely or goes back to rough idle. The battery has been disconnected overnight so the ECM could relearn, but goes right back to the same thing. Sometimes the check engine light flashes, sometimes solid, sometimes not on at all. And today it developed a new issue. The speedometer shows the needle pegged out at 100, the gas gauge is almost upside down as well as the temp gauge. I'm beginning to think the damn thing is possessed! Where do I go from here? I'm lost.
Old Apr 13, 2017 | 09:04 PM
rexmburns's Avatar
Super Moderator
Sounds like your cam retard is off to me.
Old Apr 13, 2017 | 09:13 PM
How do I fix that?
Old Apr 13, 2017 | 09:56 PM
rexmburns's Avatar
Super Moderator
Do a quick search and you will find the procedure.
Old Apr 14, 2017 | 10:16 AM
Strangerock's Avatar
Strangerock is on a distinguished road
check the fuel pressure regulator as well, a friends 5.7 was doing this with a bad regulator.
Old Apr 14, 2017 | 11:57 AM
newguy's Avatar
And the tires may be low on air
Old Apr 14, 2017 | 12:16 PM
LesMyer's Avatar
Figure out the codes being set. FYI disconnecting your battery doesn't reset your PCM. Maybe got that distributor in a tooth off? That will show in the codes set.
zcat23
Sep 29, 2010 10:30 AM
MidnightsPaleGlow
Jul 26, 2010 09:25 PM
ltown21
15
Dec 1, 2007 06:42 PM
