01 4.3 only starts once every few hours
Old Nov 19, 2009 | 11:08 PM
bigdawgz2006's Avatar
bigdawgz2006 is on a distinguished road
Default 01 4.3 only starts once every few hours
I have a 01 blazer 4.3 that starts great the first time but will not start again for at least an hour or two. Engine cranks and has spark. I checked for gas at the valve on the fuel line and there was pressure but do not have a gauge to put on it.
This started after replacing the motor. Is there anything I missed maybe? The motor runs great when it starts.
Any help would be appreciated
Old Nov 19, 2009 | 11:25 PM
klote82's Avatar
klote82 is an unknown quantity at this point
how long will it run? does it die or do you shut it off?
I just had to replace my fuel pump, constantly dying and shutting off on me.
Old Nov 20, 2009 | 06:05 AM
Test fuel pressure when you are experiencing the no-start.
Old Nov 20, 2009 | 07:37 AM
It stays running and there are no problems until you shut it off. then it just cranks and cranks and won't start
Old Nov 20, 2009 | 08:30 AM
svd85's Avatar
svd85 is an unknown quantity at this point
my guess is fuel pump or fuel relay.
Old Nov 20, 2009 | 09:14 AM
So... Test the pressure. It is a diagnostic starting point. The results of which can help you determine the proper direction to go in.
Old Nov 20, 2009 | 03:47 PM
I don't know exactly how I fixed it but it works great now. I started it and let it run for about 30 minutes and now it runs like a top and starts whenever you need it to. I'm thinking maybe the computer had to relearn the new motor.
kb7qdi
Dec 17, 2012 05:54 PM
ek72
Jul 14, 2011 11:09 PM
Johnny Glenn
Mar 12, 2010 10:18 AM
an240172
Nov 18, 2009 09:32 AM
Cutler
Jun 8, 2009 04:03 PM
