01 Blazer Auto 4X4 Question.
Old Sep 12, 2011 | 06:33 PM
Don Green's Avatar
Don Green is on a distinguished road
Default 01 Blazer Auto 4X4 Question.
Pretty sure my encoder motor crapped out. Question...... There's only 3 postions in the transfer case? Ahead is 4x4 low, middle is neutral and back is 2x4 4x4 high? If this is the case... if I hooked a 12 volt source switch to the vac switch on the fire wall I should have in and out of 4x4 high?
Old Sep 12, 2011 | 09:35 PM
The NV236 is a tricky transfer case. There is always some torque transmitted to the front output shaft even when in 2HI. When the transfer case is in Auto4wd, it applies more pressure on the clutch pack which transfers more power to the front axle up to a 50/50 split. 4HI is accomplished by fully applying the clutch pack. I haven't messed with one in a very long time and cannot remember the specific detent positions.
Concerning the front axle engagement solenoid, if you were to energize the solenoid, you would engage the front axle only, not the rest of the system.
madmack4
May 24, 2012 12:59 PM
mross45640
Oct 13, 2011 06:44 PM
Tinted
35
Feb 7, 2011 01:12 PM
LannyL81
Aug 8, 2010 01:01 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
