01 Blazer, ticks when cold
Old Nov 25, 2010 | 02:52 PM
dailydriver's Avatar
dailydriver is on a distinguished road
Default 01 Blazer, ticks when cold
I just bought it 2 weeks ago, it was fine the first 175 miles, last night it was cold and I started it, its ticking/knocking but I shut it off n started it a few times and it would stop, then later in the night it now starts and ticks, but once it runs for a couple minutes it stops, Im thinking its possibly a lifter not pumping up with oil for a min or 2, its coming from the passanger side, im gonna change the oil and put mobil 1 in to try to clean it out. Does anyone have any ideas or has had this happen?
its an 01 Blazer, 4.3 with 125k miles on it
Old Nov 25, 2010 | 05:58 PM
blazinloud's Avatar
pretty sure its common for these motors, although living in canada, cant say ive ever heard my valve train ticking.
Old Nov 25, 2010 | 08:02 PM
Flyfishen's Avatar
Flyfishen is on a distinguished road
I had this as well on my old 98 Blazer. Being in Canada, winters here get cold so we plug in at night to keep the block nice and toasty but it would only go away once it was ran for a couple of minutes, and then it was fine for the day until I left it sitting for a while.
When I sold it the truck had 395000 KMS on it and it did not get any worse. These motors are bullet proof. I probably should have reset the lifters after 100000 KMS but it didn't affect the performance at all so I left it alone.
Old Nov 25, 2010 | 08:58 PM
ok, yea it goes away after running for a couple of min when its cold. if its warm it doesnt do it. and it just started, like was fine, i shut it off, an hour later I start it and it was doing it. and has done it since, im deff thinking collasped lifter
Old Nov 25, 2010 | 09:51 PM
tonto5968's Avatar
tonto5968 is on a distinguished road
try wynns fifty-plus....works good to quiet down ticking...i use it with regular maintenance
Old Dec 2, 2010 | 12:07 AM
JustJerry's Avatar
JustJerry is on a distinguished road
If I were you I would change my oil and filter and replace one quart of oil with Rislone, them in about 3,000 miles do so again.
Not long back I had a bad sticking lifter on start up on my 91 blazer 4.3 W engine, and that is what I did and I got rid of the problem. I would suggest using a very good 5W 40W oil.
That has been a good while back when I had that trouble, I still put 1/2 of a quart in at oil change, leaning out 1/2 quart of oil of course.
Rislone will not damage you engine, can't say the same for other additives, its one of the few additives that I have found in my 63 years that works.
nnaidas
May 7, 2015 10:18 AM
98huntergreenblazer
May 21, 2012 02:52 PM
mackjefferson
Jun 16, 2009 11:40 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
as2higpark
Oct 18, 2007 12:18 PM
