01 blazer trans wont come out!! need help ASAP
Old Aug 20, 2011 | 11:01 AM
lght1622r's Avatar
lght1622r is on a distinguished road
Default 01 blazer trans wont come out!! need help ASAP
I have an 01 blazer 4x4. i have everything unhooked and the trans just wont let go from the top. I have all 9 bellhousing bolts out and the tranfer case is off already. all 3 torque convertor bolts are out too. Need help before i set this thing on fire. .
thanks in advance.
Old Aug 20, 2011 | 12:58 PM
TZFBird's Avatar
TZFBird is on a distinguished road
There are 2 locating pins on either side of the engine block that keep the transmission lined up during installation. These can get a bit corroded since it is steel against aluminum. They are about in the middle between the two bolts that were on the sides. Spray them down with penetrating oil(WD-40, Kroil, PB Blaster, etc.). You're going to need to rock the transmission side-to-side and it should come free. It's a PITA, but they are fairly tight to begin with and a little rust or corrosion does not help. A little anti-sieze on the pins during installation would help for the future. Just in case.
But if they are free already, I think there are only the 6 bolts on the top half plus whatever is on the bottom of the bellhousing. I have not worked on any 4L60e's newer than '95 though so I'm going from what I've been told.
Old Aug 20, 2011 | 02:15 PM
darin89's Avatar
darin89 is on a distinguished road
are you positive only 3 torque converter bolts most vehicles i have worked on have 4 atleast . just another option
Old Aug 20, 2011 | 04:21 PM
MonkeyGein's Avatar
MonkeyGein is on a distinguished road
there was only 3 on mine. i had trouble too. i just pryed on it. min had a little hole at the bottom on thge BH. hammer a philips in there and just work it with a flat and smal pry bar. that's what worked for me
Old Sep 13, 2011 | 09:54 PM
karmtec's Avatar
karmtec is on a distinguished road
I jacked mine up a bit to take pressure off the dowel pins then used a thin scredriver and tapped lightly with a hammer at mating surface to seperate.
myxil
Jan 16, 2014 05:31 PM
twotonethunder
Jan 26, 2010 06:09 AM
nitro7
Jan 10, 2010 03:09 PM
cartunez2004
14
Sep 25, 2009 10:31 PM
machinist99
Dec 3, 2007 11:18 AM
