01 chevy blazer 4wd replaced the tranny BUT please read on
Old Apr 8, 2010 | 10:59 AM
kyle123's Avatar
kyle123 is on a distinguished road
Default 01 chevy blazer 4wd replaced the tranny BUT please read on
I replaced the transmission put everything together. Took it off the ramps worked great. Than was gonna put it back on the ramps a couple minutes later so i thought id check out 4 wd lo went into 4wd lo fine did what i had to do. I put it in 2hi and now you have to push the gas pedal down quite far for it to get going. Not in reverse tho reverse takes off good put forward it doesn't any ideas of what could be doing this? its like its not got enough torque or soemthing??? what could couse this too much tranny fluid? not enough tranny fluid not enough transfer case fluid soemthing????
Old Apr 8, 2010 | 11:00 AM
kyle123's Avatar
please help
Old Apr 8, 2010 | 11:45 AM
96Blazernut's Avatar
96Blazernut is an unknown quantity at this point
Check your transmission fluid in park with the engine idling, also check your parking brake.
Old Apr 8, 2010 | 12:22 PM
kyle123's Avatar
if it was the parking brake or the fluid levels both i THINK r okay wouldnt it do the same in reverse ? reverse works great atkes right off
Old Apr 8, 2010 | 02:42 PM
If your parking brakes are hanging up it will let you go in reverse and drag when going forward. Even if the brake light is not on they can still be binding up. It's just a thought.
If the tranny fluid is low it won't want to move in any direction.
kevinph
Feb 25, 2019 09:24 PM
opposedforces
Sep 1, 2011 02:59 PM
serrasalmus
Feb 20, 2011 11:20 PM
F T P
Aug 9, 2009 01:45 PM
xckid
Oct 15, 2008 05:58 PM
