01 S10 4.3 misfire at freeway speed
Old Sep 28, 2018 | 01:49 PM
Corey Evans's Avatar
Corey Evans is on a distinguished road
Default 01 S10 4.3 misfire at freeway speed
i have been trying to figure this problem out for a while now but i cant figure it out, when i try to get on the freeway my engine starts to miss fire but if i get off the throttle for a few seconds then get back on it it levels out then starts to run correctly i have changed the spark plugs ignition wires and distributor i have also put in a new fuel pump, i do have a small exhaust leak but i can never find it, it sounds like its coming from the passenger side if any one has a similar problem i would be grate to hear what you have to say
Old Oct 2, 2018 | 09:27 PM
steveduns's Avatar
steveduns is on a distinguished road
When it misfires does it fell like it's cutting out and jerking hard or is it more subtle? Only reason I ask is I had a similar thing happen on my 2000 Blazer until I looked down and saw the tach jumping at the same time - trans was slipping just a little. It took me a while to figure it out because it felt like a slight hesitation. Just a thought.
strosniderd
Apr 26, 2018 03:50 AM
travisrussell88
14
Jul 3, 2010 08:35 PM
okcblazer74
Oct 5, 2009 08:37 AM
1996BZR
19
Dec 23, 2008 03:07 PM
blzrgrl
Nov 5, 2007 09:13 AM
