01 w code 4.3 EVERYTHING works,NO SPARK
Capt.
I Just Got A Factory Plug From A 2000 Blazer That Has My Ppl/Yel/Gn Wire Combo. I Plan To Wire It In And Solder It When I Get Back Home. Had To Drive 70 Mi. Go The Nearest Yard That Let's The Gen Pub On The Lot.
I Will Let You Know What Happens After I Try it.
Yeee Haaa! See if your auto xray can/will initiate the crankshaft position sensor relearn. It will instruct you to bring engine RPM to 4K and let off the gas when the PCM takes over control. After that you'll need to check/adjust camshaft retard.
I'm Not Sure If It Will. I Know It Will Allow Me To See The Actual Figures As It Is Running,But Not Adjust Anything I Don't Believe.
Did You Get My Number In The Email? If So,Would You Give Me A Call? I Am Using My Droid RAZR As A Comp.To Communicate With Hour,And For Some Reason It Keeps Wanting To Good Up On Me.
Or,Email Me A Number For You,And I Can Contact You.. This Way,I Can Listen To HouraAdvice And Check It With My Hands Free Instead Of Having To Look It Up On My Phone And Fight With It Along With The Truck.
If You Don't Mind ,That Is..
thiefinthenight
Aug 25, 2012 11:03 AM
cougar1997xr7
Apr 6, 2012 04:09 PM
rocker665
Oct 23, 2011 01:55 PM
YOURCONNEXX
Oct 21, 2009 07:10 PM
xluke
Feb 1, 2009 10:33 PM
