'02 Blazer Check Engine Light on, won't go past 55 mph - HELP!
Old Jul 17, 2011 | 11:00 PM
BlazerChick88's Avatar
BlazerChick88 is on a distinguished road
Red face '02 Blazer Check Engine Light on, won't go past 55 mph - HELP!
My check engine light recently came on & now my truck won't go over 55 mph. There's some noise near the Catalytic Converter area & when I took it to get plugged in I had 2 codes come up - 1 was about the MAF sensor & the other was about the Catalytic converter. Is there an easy fix for this?? How will I know exactly WHAT I need to have done?
Old Jul 17, 2011 | 11:22 PM
rriddle3's Avatar
It's hard to answer without knowing what the exact code numbers were, but start with this thread - How to: MAF Sensor Cleaning - DISCUSSION THREAD. The noise from the cat probably is the burnt out and broken up insides that have plugged it (and perhaps the muffler) up. If that is the case, it will have to be replaced.
Old Jul 19, 2011 | 11:41 AM
THANK YOU!! That's more help then I've gotten from my own family!! The codes are P0420 and P0101
Old Jul 19, 2011 | 11:44 AM
Here are the code listings:
P0101 - Mass Air Flow System Performance
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
I would definitely recommend cleaning the MAF before going to any other more expensive options.
As far as the catalytic converter goes, if it's making noise, it will only get worse and could potentially leave you stranded somewhere.
doccheese
Dec 12, 2014 03:43 PM
914door
Oct 13, 2011 04:34 PM
sbleier
Feb 3, 2011 10:12 AM
goodguy
Aug 6, 2010 09:47 PM
Bybsurfr32
Sep 1, 2009 09:17 PM
