04 Blazer fuel pressure confusion
Old May 12, 2017 | 09:50 AM
Raman04's Avatar
Raman04 is on a distinguished road
Originally Posted by Raman04
Is it worth the cost to covert to a multi port spider?
Convert not covert
Old May 12, 2017 | 10:18 AM
LesMyer's Avatar
If there is anything wrong with the old one (regulator, poppet leaking, etc) I would not spend any money repairing the old one. That said, the upgrade spider can be pretty pricey. You will notice no difference in performance if your old spider is working properly. If you decide to go with a new MPFI spider, we typically recommend the AC Delco one. If the fuel pump check valve is not the cause of your pressure decay (as shown by testing with fuel pump sticky), you might want to consider just throwing on a new spider since the cause would then have to lie somewhere in that assembly.
Old May 12, 2017 | 04:01 PM
Raman04's Avatar
I will test the fuel pump per the sticky and replace the fuel filter as it has been a while. Probably have to take off the intake and check for leaks so nothing gets overlooked. Saw a youtube video on it not so daunting now.
Old May 12, 2017 | 04:05 PM
Raman04's Avatar
As far as replacing the spider, can't I remove the intake and reconnect just the fuel lines amd turn the key to accessory. Wouldn't that show a leak anywhere in the spider asnd regulator assembly?
Old May 12, 2017 | 07:51 PM
LesMyer's Avatar
Not if the cause for the observed pressure drop is the regulator being stuck open a bit. Would be difficult to do, and would only show leaks external to the spider - but there is no reason that you can't do it if you really want to. Don't think key on accessory will energize the fuel pump though.
p.s I'm out of town for my son's wedding this weekend - leaving tomorrow morning.
Shtbox
Engine & Internal
Nov 27, 2014 05:23 PM
snuffymagee
Mar 4, 2013 09:05 PM
uncle_egg820
Jul 8, 2012 01:33 PM
PABlazer
Dec 10, 2008 02:31 AM
dbleon
Dec 29, 2007 06:04 PM
