195 thermostat to 160
Old Mar 11, 2010 | 11:27 AM
ozzman39's Avatar
ozzman39 is on a distinguished road
Default 195 thermostat to 160
Hello had a question about thermostats on a 2003 blazer LS
as im sure u know a stock one is 195 i don't like it running that ware if something goes wrong there's not much room to get her shut down and pulled over so i ordered a 160 degree thermostat from summit my question is since 195 is stock temp on these is it going to throw back a error code and check engine if I do this ? im shure all of you know its better for a motor to run at cooler temps obviously not temps that u need a choke to run but cooler temps.
Old Mar 11, 2010 | 12:04 PM
Your truck will complain with that low of a thermostat in it. It also will not run efficiently.
Stick with stock. There is nothing wrong with running with a 195*F stat.
Old Mar 11, 2010 | 12:28 PM
ozzman39's Avatar
Have u seen this happen? i know its not the same thing but i have a buddy that did the same thing to a dodge durango with no issues
Old Mar 11, 2010 | 12:41 PM
Yes, I have. It will throw a engine temp not reaching thermostat regulating temp code. The PCM is looking for the engine temperature to rise a certain amount in a set time frame. With a colder t-stat (even as cold as 180*F) the warm up time can increase to the point where the code will set.
If you have the PCM modified to change this and to operate more efficiently given the cooler operating temperatures, then you should be good, but just dropping in a colder t-stat isn't going to give you favorable results.
Old Mar 11, 2010 | 12:53 PM
ozzman39's Avatar
Thanks for the input
Old Mar 11, 2010 | 01:43 PM
Vahomboy's Avatar
Vahomboy is on a distinguished road
On my 02, the t-stat was sticking open some and it caused it to throw a light. New stat, no more light.
Old Mar 11, 2010 | 02:28 PM
ozzman39's Avatar
what temp T-stat did u put back in
Old Mar 12, 2010 | 12:03 PM
Vahomboy's Avatar
OEM recommendations. 190-195?
Old Mar 12, 2010 | 12:25 PM
abig84's Avatar
Also your heat will suck too. I had the same thought process and did this in a 83. So no computer to mess up but the heat was just warm
Old Mar 20, 2010 | 07:13 PM
cooper232's Avatar
cooper232 is on a distinguished road
i just put in a new stock 195* t-stat and i am not sure that the gauge is right or not. does this look right? the increments are funky. from the first to the middle is 100-210 so that makes the 1/4 mark 155 but from the middle to the top is 210-260 so that makes 3/4 mark 235. do you think i need a new water temperature sensor that goes into the t-stat housing?
