1970 eating up starters
Old Nov 21, 2020 | 02:11 PM
SorenG's Avatar
SorenG is on a distinguished road
Default 1970 eating up starters
So my 1970, 350 4wd automatic blazer has gone through about 4 or 5 starters. It currently doesnt run because the starter on it now is out. It works for a while then the starters seem to grind then a couple days later the starter wont engage at all. I'm looking for help as to what I am doing wrong. I have taken it to a few shops and put in a couple myself but something isnt working right.
Old Nov 21, 2020 | 02:37 PM
Offroad King Tut's Avatar
Offroad King Tut is on a distinguished road
What does the teeth on your flywheel look like?
What do the teeth on the starter look like?
Does the solenoid engage?
Old Nov 21, 2020 | 09:24 PM
Transman304's Avatar
Some GM starters require shimming to get proper mesh of gears. Check the teeth on the flex plate. You remove the starter and will have to turn engine over by harmonic balancer bolt on front of engine. Most of the time you will find 4 bad spots/ missing teeth around the circumstance of ring gear.
Misaligned Starter / Improperly shimmed.
Defective/Damaged Starter Gear
Defective/Damaged Starter Bendix.
Loose Flexplate Bolts
Trying to start the engine when it is already running.
Brad
Old Nov 22, 2020 | 11:57 AM
SorenG's Avatar
I have replaced the flywheel one of the times because it was damaged, it sounds like it hasn't been in the right spot, would you know the proper way to get it the right height with the shims?
Old Nov 22, 2020 | 04:02 PM
YouTube is your friend on this procedure.
Brad
Old Mar 22, 2021 | 08:31 PM
mark71j's Avatar
mark71j is on a distinguished road
How'd that work out?
Kipper667
Aug 4, 2014 05:36 PM
brino1
Nov 27, 2012 06:13 PM
ElevenevelE
Jun 18, 2010 03:11 PM
chapy
Feb 27, 2009 05:39 PM
laserblazer
Jan 29, 2007 05:52 PM
