2003 4x4 hard start , sputters and more
Old Mar 24, 2021 | 06:40 PM
Corey Bennett's Avatar
Corey Bennett is on a distinguished road
Default 2003 4x4 hard start , sputters and more
Good day all ,
ive got a 2003 blazer 4x4 that’s suddenly having a hard time starting . Once it does start it sputters badly , nearly dies when I shift gears , idles rough . Once it’s warm it seems ok until breaking and then it sputters .
I just change the oil , spark plugs and topped off trans fluid .
any ideas ? Need this vehicle to last me another year until I can upgrade? Symptoms seem to match a fuel filter/pump issue but I’m at my wits end .
Old Mar 24, 2021 | 07:10 PM
If you don't want to throw parts at it, I would do a pressure test.
Was this happening before the oil change?
Old Mar 24, 2021 | 07:26 PM
yes , sporadically though!
Old Mar 25, 2021 | 06:45 AM
If you haven't done the fuel filter, I would start with that... its easier then the pump, and sometimes gets clogged, causing the pump to work harder and fail sooner.
But the fuel pressure test will tell you for sure if you even need to do that lol...
Blazerbrain
Dec 27, 2020 07:38 PM
Nhackert
Oct 29, 2016 12:12 AM
lmo
Nov 17, 2010 06:10 PM
Dfretty
Sep 1, 2010 09:14 AM
jaybone420
Oct 15, 2005 03:04 PM
