1987 Blazer Low oil pressure
Old Jun 11, 2009 | 07:51 PM
Hp1's Avatar
Hp1
Hp1 is on a distinguished road
Unhappy 1987 Blazer Low oil pressure
I have an 1987 Blazer with 190,000 miles. Well serviced over the years.
It has developed low oil pressure, when warmed up only shows a few
psi. Pressure does go up when eng rpm is increased. Changed the oil
pressure sender, same results.
Suggestions?
Hp1
Old Jun 11, 2009 | 08:30 PM
Probably either a weak pump or increased clearances on the main bearing journals due to age. Sounds like an engine rebuild is in your future.
snakize1978
Sep 16, 2012 12:42 PM
GryphonBlaze
13
Oct 19, 2011 07:24 AM
jnail
Sep 5, 2009 10:44 AM
bdenczek
Jul 22, 2009 10:47 AM
encryptedzion
May 17, 2009 07:19 AM
