Low oil pressure 2000 Blazer
Old Jul 22, 2009 | 06:55 AM
bdenczek's Avatar
bdenczek is on a distinguished road
Question Low oil pressure 2000 Blazer
When I first start my Blazer my oil pressure is at 40 after the truck warms up it drops to 20 and when I stop it drops to 0 and the check engine light comes on. I have taken it to two shops (one a chevy dealer) and they say they can't see what I am talking about. Anyone have any suggestions?
Old Jul 22, 2009 | 07:05 AM
ant2297's Avatar
ant2297 is an unknown quantity at this point
are there any unusual noises coming from the engine? could be bad pump, worn bearings. did you change the oil recently? did this happen after any work was done to the truck or slowly progressed?
Old Jul 22, 2009 | 07:13 AM
bdenczek's Avatar
I recently had the valve cover gasket and intake manifold gasket changed. they also changed the oil at the same time. I noticed it after the work was done. There is no noise in the engine.
Old Jul 22, 2009 | 08:07 AM
rriddle3's Avatar
You need to connect a manual oil pressure gauge to the sending unit connector to verify whether this is actually happening or if it's the dash gauge acting up.
Old Jul 22, 2009 | 10:47 AM
bdenczek's Avatar
Thank you for taking the time to help. I will have it looked at.
snakize1978
Sep 16, 2012 12:42 PM
GryphonBlaze
13
Oct 19, 2011 07:24 AM
jnail
Sep 5, 2009 10:44 AM
Hp1
Jun 11, 2009 08:30 PM
encryptedzion
May 17, 2009 07:19 AM
