1987 Chevy Blazer Clutch/Transmission Issue
Old Nov 8, 2009 | 05:14 PM
Raquel's Avatar
Raquel is on a distinguished road
Default 1987 Chevy Blazer Clutch/Transmission Issue
My question is about a 1987 Chevy Blazer. The slave cylinder and the master cylinder have been replaced. The clutch wasn't building any pressure. We finally got the pressure built but it slipped within less than a block of driving.
It appears that the throw out lever (or maybe it is called the clutch fork??) is slipping off the throw out bearing. Does anyone know why this might be happening?
Old Nov 8, 2009 | 06:00 PM
Is the clutch fork still fixed on the ball/socket joint on the bell housing. If it is, then you may have a damaged fork where it rides on the throw out bearing. That and/or maybe a broken throw out bearing.
Old Nov 8, 2009 | 09:35 PM
Raquel's Avatar
Smile
Thank you. I believe it is. I will pass that suggestion on to my father-in-law. Crossing my fingers!
Thanks again!
Chivas1
Jun 7, 2012 11:35 AM
RicoJay13
Jul 18, 2011 10:06 AM
MintyMadness
Jul 13, 2011 12:37 AM
chev4scott1989
Apr 12, 2011 11:35 PM
Red03
Sep 25, 2008 08:37 PM
