1993 s-10 blazer won't shift
Hello...My 1993 s-10 blazer 4x4 was shifting just fine and now will only shift manually.....I changed fluid and filter and it is no better...I have changed egr,knock sensor ,plugs,wires,cap,rotor,....please help.....anything I can try...vacuum lines appear intact...thanks also already changed spider
Thank you for helping me...I will locate the speed sensor and change that....also I will re-post when I figure out what transmission i have....You guys are GREAT.....also I will locate fuse and see about checking voltage
TimberwolfFXDL
Aug 4, 2013 07:28 PM
andrewrj
May 6, 2012 07:28 PM
jes9999
Mar 12, 2006 01:40 AM
