1994 4.3 Blazer running rough
Old Jan 19, 2009 | 08:59 PM
  #31
Default RE: 1994 4.3 Blazer running rough
The engine cooling fan is a self contained thermo-viscous clutch fan with no external control so as I said, the computer has no control over it. It locks up when the air passing over the clutch gets hot.
Old Jan 20, 2009 | 12:59 PM
  #32
sarmikgar's Avatar
sarmikgar is an unknown quantity at this point
Ahh, you are correct.. I hadnt looked yet, just assumed it was electric.
Old Jan 20, 2009 | 07:27 PM
  #33
sarmikgar's Avatar
Threw a new EGR on it, it is better, smoother at idle for sure and slightly smoother as the rpms go up.. but seems to lack alot of power and has slight miss still. Never drove truck before, but throttle response and overall power should be better I think.
Ran codes again and got 32 and 34. Wondering if I should get a new MAP sensor and try that.
Owner of vehicle coming tomorrow to pick it up. Kinda glad to be getting it out of my garage, but would love to have it running good as can be expected for him.
Any help is much appreciated!
Old Jan 22, 2009 | 12:21 PM
  #34
sarmikgar's Avatar
Took the truck in to an exhaust shop and they said the cat was good, next door was a repair shop and I had a diagnostic test run for $65 there. I didnt know they could see all the things they can on these older obd1/1.5 cars... Anyway, turns out #2 and #4 arent getting fuel=new spider, yay [:@]
Any helpful tips or hints needed for installing it would be much appreciated.
Old Jan 22, 2009 | 12:57 PM
  #35
Outsydr's Avatar
Outsydr is an unknown quantity at this point
there is a walkthrough on this site for it (cut off due to a server hack several months ago) swart was working on redoing it but has not had time to finish yet but in the meantime I put one on our sister site you can check it out Here (original on this site is linked to also as that was a source I used, proper credit where it is due and all)
Old Jan 22, 2009 | 03:18 PM
  #36
sarmikgar's Avatar
Thank you very much Outsydr, that will be a big help.
Can you tell me if I need to buy the fuel feed and return lines separately from the spider.. are the fuel lines whats called the "nut kit" and that is a separate part from the spider unit or is it all in one?
Old Jan 22, 2009 | 03:20 PM
  #37
sarmikgar's Avatar
Ahh answered my own question, just needed to look at that page a bit more.
Will an Autozone or other local parts type place carry the nut kit usually?
Thanks again for the help.
Old Jan 22, 2009 | 05:30 PM
  #38
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
NAPA usually carries the nut kit, both with and without the support bracket (it's cheaper without, so if your bracket & screw are in good shape, get it without).
Old Jan 23, 2009 | 02:47 PM
  #39
sarmikgar's Avatar
After installing new spider unit truck runs great.
Thanks very much for all the help I recieved here.
Old Jan 23, 2009 | 07:48 PM
  #40
Great!
blazerguy22
Nov 14, 2013 11:50 PM
ksimpson
14
Oct 7, 2013 05:25 AM
Farmer01
Dec 11, 2012 04:34 PM
nhguy261
Dec 30, 2010 01:41 PM
sweet-98ta
Jan 5, 2010 12:56 PM
