1994 Blazer with idle troubles...
1994 Chevy Blazer 4.3L 2WD V6
Yesterday we changed the plugs & wires on my Blazer because it had a slight miss... Plugs were ugly with black soot on them... This morning the Blazer is sputtering & cutting out on acceleration & idles rough & reeks of gas... We just checked the distributor cap & rotor & found nothing wrong there... I had NAPA run and OBD1... It showed only code 12 which they say means all is fine... I've checked & re-checked all wires & plugs for tightness... Checked the firing order & it is right... I can't find any obvious reason why the sudden change... If anyone has any ideas they will be greatly appreciated since this is my only mode of transportation & it is costing me work... Bear in mind, this vehicle was not in tip-top running order to begin with, but it didn't seem to run bad...
Hopefully others (that are more in tune with 94's) will chime in soon.
In the meantime try searching for something like "1994 running rich" "1994 sputtering" etc, change up the wording & read on. Good luck, but I'm sure the answer is here.
ga_blazer
Sep 14, 2014 10:58 PM
rex seacat
Jan 21, 2013 06:57 PM
nzvlnr
Aug 17, 2011 09:45 AM
DOUGHboy79
13
Feb 26, 2008 05:20 PM
CrashPro993
Nov 8, 2007 04:32 PM
