1995 4.3 #6 misfire
Old Nov 30, 2008 | 11:32 PM
Idontknowwhy's Avatar
Idontknowwhy is an unknown quantity at this point
Default 1995 4.3 #6 misfire
Have a 1995 4.3 blazer with CPI, beginning to think it is cursed..
Been nothing but a money pit since day one..
But now, have a problem that can't pinpoint and looking for any suggestions as to what it may be.
#6 misfire at idle and under acceleration
Scanner is giving p0306 code, which was already obvious as it is a dead cylinder
Have replaced plugs, wires, coil, distributor, ecm, knock sensors,
Compression seems fine
Took #6 wire off to check for spark and its showing a weak spark, have swapped wires from neighboring cylinders and even other plugs, still the same..
I know the CPI seems to be a usual culprit with misfires and also the egr valve, but my problem seems to be on the ignition side, but i cannot think of what else could cause just one cylinder to have a weak spark, have replaced everything i can think of...
Any ideas would be appreciated before i go melt this hunk of junk down..
Thanks
-John
Old Dec 2, 2008 | 03:37 PM
ant2297's Avatar
ant2297 is an unknown quantity at this point
Default RE: 1995 4.3 #6 misfire
cam sensor?
Old Dec 3, 2008 | 12:33 AM
No idea, it's got an appointment with the local chevy dealership. Don't have the time to **** with it anymore. Will update on what problem is, if they can even figure it out! haha
Old Dec 12, 2008 | 09:38 PM
volfan4's Avatar
volfan4 is an unknown quantity at this point
did ya figure it out?
stephen5217
Feb 17, 2022 10:07 AM
rrk03300
Nov 15, 2012 10:29 PM
95chevrolets10blazer
Nov 7, 2011 08:37 PM
wythel
27
Jan 30, 2006 02:04 AM
wolfe1967
Aug 29, 2005 12:27 AM
