1995 Blazer with blown engine
Old Dec 8, 2011 | 12:05 PM
Homeys1995's Avatar
Homeys1995 is on a distinguished road
Default 1995 Blazer with blown engine
Could someone help me understand what year 4.3l vortec motor I could replace this engine with if I can't find a 1995. I want to just pull this motor out and drop a different one in. Also what is the difference with the top or side mounted spark plug wires to cap?
Old Dec 8, 2011 | 12:21 PM
If you have the EDI distributor (horizontal mounted plug wires at the cap), you'll have to find another EDI '95 for it to be a direct drop in. The standard ignition system used in the early '95's (vertical mounted plug wires at the cap) did not use a CKP sensor on the front of the engine. The short block from a '96 would work, however you would have to swap over the heads on up from your '95 motor. The cam would be different as well, but probably negligible in terms of noticeable performance difference.
If you don't have the EDI distributor, then you should be able to use any '93-'95 CPI engine.
Old Dec 8, 2011 | 02:10 PM
Homeys1995's Avatar
Thank you that is a big help because I looked at a few engines with vertical mounted plug wires and mine has horizontal mounted plug wires.
limited edition 1
Jan 27, 2023 11:07 AM
tperk77
Apr 30, 2012 10:11 PM
BLOND1WD
Jan 31, 2011 07:38 PM
98Ltblazer
Nov 21, 2010 02:24 PM
black99xtreme
May 8, 2007 12:55 PM
