1995 chevy blazer 4.3 missing real bad.
Old Jan 20, 2016 | 08:02 AM
sowellj22's Avatar
sowellj22 is on a distinguished road
Default 1995 chevy blazer 4.3 missing real bad.
I have a 1995 chevy blazer 4.3 that is missing bad. No codes. Just changed the fuel pump. Direct pressure on pump is in the 60s but when hooked to the Schrader valve its like in the 59s and when running its in the hight 40s to low 50s. My guess is that's whats causing the misfire. but what would cause this other than fueal pump because it is new. Its not as bad when going highway speeds but its sucking down gas and has a little time accelerating unless I give the pedal a good press please anything to help would be great.
Old Jan 21, 2016 | 04:57 PM
Red Sled's Avatar
Red Sled is on a distinguished road
Just because the pump is new doesn't mean its not JUNK! As with tune-up parts I wouldn't use any thing but a Delphi or Delco fuel pump. Do a search on how to test fuel pumps.
Old Jan 25, 2018 | 09:07 AM
K9CSW's Avatar
K9CSW is on a distinguished road
Unplug the MAP sensor see if it still does it, if so, get a new one. An MAP sensor is to the left of the spider injector plug and has three wires.
or the distributer, wires, and spark plugs
the cat or air filter
vacuum leaks
it goes on and on
bigeddieoh
Apr 19, 2015 11:35 AM
matt92
Jun 18, 2011 12:28 AM
Mange98
14
Feb 24, 2011 03:18 PM
djdrew010
Oct 29, 2008 08:20 PM
97blz4x4
Dec 18, 2006 10:13 PM
