1995 chevy s-10 Blazer won't cold start
Old Feb 12, 2012 | 07:25 PM
Sky's Avatar
Sky
Sky is on a distinguished road
Default 1995 chevy s-10 Blazer won't cold start
I have a 1995 s-10 blazer that will not start when it is cold out. During the summer, it starts up no problem. as soon as the cold weather hits, it won't start. If i leave it in my garage with the heater on, it will start up after a while without a problem and will run. If it sits too long in the cold afterwards, then it won't start yet again. I have put a new fuel filter, fuel pressure regulator, pickup coil, coil, plugs, plug wires, distributor cap, rotar button, and crank sensor on it. It is still having this problem. Any helpful advice would be appriciated!!!!
Old Feb 12, 2012 | 07:36 PM
Have you tested your fuel pressure when the no-start condition occurs?
Old Feb 12, 2012 | 07:45 PM
Sky's Avatar
Sky
yes i did. It was about 55 psi
Old Feb 12, 2012 | 07:47 PM
It needs to be >55psi for proper operation of the engine, but lets assume that your gauge reads low and move on.
Have you tried wiggling the wires that run to the fuel injection spider inside the manifold? They exit under the throttle body.
What brand of ignition components did you use?
Old Feb 12, 2012 | 07:50 PM
Sky's Avatar
Sky
what would wiggling the wire do for it?
Old Feb 12, 2012 | 07:53 PM
Many people have chased problems only to find that the connector on the injector inside the plenum was loose & in need of replacement. Pulling the wires can allow the contacts to complete the circuit resulting in a working engine, even if temporary.
Old Feb 12, 2012 | 07:57 PM
Sky's Avatar
Sky
If thats what the problem is, then why does it only do it when its cold outside?
Old Feb 12, 2012 | 07:58 PM
For something that is so easy to try, I'm not sure why you are being so hard headed about it... Regardless, I'll play your game this once, but then I'm out. When its cold out, wires constrict, plastic moves, etc.
Good luck with your problem.
Old Feb 12, 2012 | 08:01 PM
Sky's Avatar
Sky
sorry about that, i'll give it a try. And thank you
So I tried to wiggle the wires, but all it wanted to do is just crank over, like its been doing. Still won't start
Last edited by swartlkk; Feb 12, 2012 at 08:15 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Feb 12, 2012 | 08:28 PM
247monster's Avatar
it sounds like your battery is weak to me...happens alot up here when it gets cold easy to check too but its also easy to forget
