1995 Jimmy 4X4 Automatic Tranny Oil Change
Old Jun 12, 2011 | 01:24 AM
the Fllash's Avatar
the Fllash is on a distinguished road
Default 1995 Jimmy 4X4 Automatic Tranny Oil Change
I changed my 1994 Jimmy 4X4's automatic transmission oil and filter. On the back side of the transfercase there is a drain plug and I removed that and automatic tranny fluid drained out.
My question is when I refill the automatic tranny via the dipstick/tube will that fill the transfercase too?
It only took about 5 quarts of oil to bring the dipstick to the full mark.
Thanks for your reply.
The Fllash
Old Jun 12, 2011 | 09:57 AM
oisinirish's Avatar
Most likely the transfer cas was filled with trans fluid. That is pretty standard on the older ones. Like mine. I suspect you will need to fill the transfer case separately. The two systems are not connected, I don't believe.
How much fluid came out of the tranny? How much from the transfer case? 5 quarts seems short to fill both.
What I could find:
Tansmission on fluid change takes 5 quarts.
Transer case=Should be a tag on the back.
Np231 and 233=1 quart
Nv136 and 236= 2 quarts
Old Jun 12, 2011 | 01:19 PM
the Fllash's Avatar
oisinirish,
Thanks. I checked my owners manual this morning and yes it does fill separately and uses ATF.
Athlon2012
Mar 18, 2015 08:28 PM
scphill34
Mar 26, 2013 07:09 PM
reddheadnla
Apr 4, 2011 06:27 PM
RickBlazer
May 26, 2010 04:33 PM
OldJr88
Aug 13, 2009 12:13 AM
