1997 4 wheel drive
Old Sep 13, 2010 | 07:41 PM
truck317's Avatar
truck317 is on a distinguished road
Default 1997 4 wheel drive
So i just got this blazer and it has been sitting for over a year and the 4 wheel drive don't work. when i put it into neutral and press the 4 high button the the 4 high and 4 low button both flashes at the same time and when i try to put it into gear both lights go off. so whats up with my 4 wheel drive
Old Sep 13, 2010 | 08:34 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
If its been sitting for that long it could be as simple as a stuck conector gear sleeve. generally your suppose to engage the 4x4 at least once a month to keep it free. This is all located in the front defferential. There's an output shaft gear and the connector sleeve gear rest on this and sometimes gets stuck after being there for a wile. A fork is connected to this gear and the fork to a cable, cable to vaccuum diaphram. Now I don't know if you can just grap the cable and force it free (wouldn't reccomend it) but others might know. Also these systems are used to be moving slightly to completely mesh (aka vehicle moving slightly also). Second thing I'm wondering is the transfer case engaging(an electric motor does this and you should be able to hear it)
p.s. you prbly should put this in the drivetrain section that deals with the transfer case and differentials.(don't worry i made the same mistake earlier)
mirrorimij
Jun 8, 2019 03:34 PM
Blade_24k
Feb 26, 2014 03:03 PM
lizzj70
Jun 23, 2010 06:57 PM
blazerduo
Dec 17, 2009 10:54 AM
carterx
May 21, 2009 08:30 PM
