1997 blazer 4x4
Old Mar 27, 2015 | 03:24 PM
Jim Cravens's Avatar
Jim Cravens is on a distinguished road
Default 1997 blazer 4x4
I have a 97 blazer other day I was driving heard no noises and lost all gears. I went out next morning started it up I had reverse, 1st gear, and 2 ND gear till it shifted into 3rd gear then I lost them all again. Any help would greatly be appreciated
Old Mar 28, 2015 | 04:51 AM
We have also ran scans on it and got no codes
Old Apr 3, 2015 | 05:32 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
3 to 4 clutches are gone. time for a rebuild. You could check the shift solenoid for 3-4 but most likely the clutches. This transmission has known issues with them.
Old Apr 5, 2015 | 09:14 AM
bdeturck13's Avatar
bdeturck13 is on a distinguished road
check the transmission fluid also. a lot of those 9x blazers had problems with the radiator breaching between the transmission cooling and the engine cooling, causing darkening coolant and antifreeze mixing with the tranny fluid, which will cause failure when warm. I had that, and ended up replacing the tranny, the radiator, and going with an external tranny cooler instead of the combo
jasonv
Nov 22, 2010 11:31 AM
jorg
Aug 22, 2010 03:47 PM
mtsumedi
Lifting Tech
13
Oct 28, 2009 09:44 PM
devonlawrence
Jun 30, 2009 09:36 AM
vtlew
Jun 23, 2006 09:13 PM
