1997 Chevy Blazer w/ dual alternators
Old Dec 17, 2015 | 07:21 PM
Bigbodylexus's Avatar
Bigbodylexus is on a distinguished road
Default 1997 Chevy Blazer w/ dual alternators
I have a 1997 Chevy Blazer that I want to run dual alts in. It is actually already setup to do this but I would like to run dual alts and keep the A/C. I need the power for my sound system, I have a guy that builds the brackets but I am curious how to install it because of the A/C lines that are on the passenger side of the engine.
Old Dec 18, 2015 | 05:22 AM
Toocute350's Avatar
Toocute350 is on a distinguished road
Man it sounds like your gonna install 2 1000 amps ha?It`s really not neccesary to hook up 2 alternators just for a high powered stereo system.What other power sources are you running besides a high powered amp and or amps?Do you have a winch,roof rack lights?I`ve never seen or heard anyone having 2 alternators on a s10/s10 blazer before.I`ve only seen a military style Chevy Blazer/scottsdale long bed pick up that had 2 alternators.If you just have a amp to worry about..You can replace the alternator you have now,with a much more high powered alternator.You should post some pics on this matter, that way we can see what your working on.usually when you have 2 alternators, you will need to have 2 batteries also.
Old Dec 18, 2015 | 07:12 AM
I already have a 200 amp alternator and I am going to use a lithium battery to help with the power demand. I plan on running about 14,000 watts. There is a guy that makes a bracket for the S-10 Blazer but my concern is that it mounts right next to the stock alternator and the A/C lines are right next to the stock alternator.
Old Dec 18, 2015 | 02:26 PM
El_Beautor's Avatar
If you have a source for a custom 2nd alternator bracket that keeps the factory AC, then they should have pictures of the setup and a description of how to install it. You might end up having to have custom AC lines made to reroute them out of the way.
Old Dec 18, 2015 | 03:43 PM
Jamaroon's Avatar
looks like this guy kept his a/c lines there
Attached Thumbnails 1997 Chevy Blazer w/ dual alternators-dsc_8730.jpg
Old Dec 19, 2015 | 11:55 AM
NWCoffee1's Avatar
NWCoffee1 is on a distinguished road
My question is: What is the part stock number for the dual alternators?
Thanks!
Old Dec 19, 2015 | 11:58 AM
NWCoffee1's Avatar
My question is: What is part number for the dual alternator belt(s)?
Thanks!
ndouglas65
May 15, 2014 07:19 AM
4.3 trooper
Dec 3, 2012 01:02 AM
bam_9_9_9
24
Oct 24, 2012 10:38 PM
headbanger35950
Dec 13, 2008 09:49 AM
