1997 EEC and 2004 4L60E transmission compatibility
Old Mar 16, 2023 | 02:03 PM
Hurgrave's Avatar
Hurgrave is on a distinguished road
Default 1997 EEC and 2004 4L60E transmission compatibility
Hello everyone!
Hope you will tell me, because I need some enlightenment .
I have 1997 S-15 Blazer L35 AWD transmission issue. Purchased it used with 4TAD code 2004 auto trans with the problem: immediately after install it runs in 1st and 2nd gears with no 3rd. After a little time falls into 'limp'. After codes erased it works the same: half dozen miles in 1-2 only, then 'limp' again. Tried another transmission (1999 code 9KXD) which seemed to have faults too. So I re-assembled my 4TAD with new parts (solenoids and inner wiring included), But the problem persists. EEC shows shift solenoids circuit failure (both 1-2 and 2-3) and other errors.
Problems seems to be in electrical parts. I can test wiring. But there's a question I didn't found an answer in ATSG and Technician's guide:
Will 1997 EEC (automatic trans) fit a 2004 code 4TAD 4l60e auto? If no, what will I need to repair/replace?
Old Mar 17, 2023 | 10:51 PM
LesMyer's Avatar
I suggest that you PM that question to Transman304
Old Mar 18, 2023 | 01:01 AM
Hurgrave's Avatar
Thanks.
my98blazer
Nov 28, 2019 10:25 PM
payasito
Oct 15, 2015 07:26 AM
nhrafan1
Oct 17, 2013 12:57 PM
BigTodd
Oct 15, 2012 05:39 PM
AtlantaRider
Dec 28, 2010 02:41 PM
