1997 Oldsmobile Bravada transmission/shift linkage problem
Old 11-11-2011, 09:57 AM
No, your transmission is full electronic control. There are no vacuum lines to the transmission itself.
Old 11-11-2011, 09:59 AM
Dillon B.'s Avatar
Dillon B. is on a distinguished road
Is there any type of module or something that would prevent it from being able to gear down with the shifter? If you dont have your foot on the gas, and shift it down, it acts like you put it into neutral.
Old 11-11-2011, 10:17 AM
Nothing should prohibit manual gear selection. It sounds like there is something amiss inside the transmission if that is not working as it should.
Your best bet is to get it to someone that knows what they are doing. You can quickly cause a $50 + labor fix to be a $1000 + labor fix by attempting to repair it yourself.
Old 11-14-2011, 08:13 AM
Dillon B.'s Avatar
Ok, so while taking my dad for a short rjde in it to show him what was going on with it, I quickly realized that the hesitation i thought i was feeling, was actually the engine running crappy. I know, i feel like a retard, lol. A new check engine code came up which was p0300 multiple cylinder misfire. Any ideas??? I bought new spark plugs (acdelco standard) and i am going to install my new coil.
WildDomesticTabby
05-21-2014 06:17 PM
bowshooter1
10-18-2011 09:47 PM
chris015
04-08-2010 11:16 AM
Quick Reply: 1997 Oldsmobile Bravada transmission/shift linkage problem
