1998 4x4 jimmy no crank no start
Old Jan 11, 2015 | 01:47 PM
Hags72's Avatar
Hags72 is on a distinguished road
Default 1998 4x4 jimmy no crank no start
I have a 1998 jimmy. The other morning it was very cold the jimmy cranked but did not start. I have had this issue before and was able to get it started with the help of starter fluid. this time i killed the battery trying to start it. So I pushed it into the street and went to work. after work I charged the battery now no crank and I cannot shift out of park. I also cannot turn the ignition back to remove the key. My battery is only 6 months old. Any thoughts of what might be wrong. Any help would be greatly appreciated.
Old Jan 14, 2015 | 09:05 PM
canuck blazer's Avatar
canuck blazer is on a distinguished road
are there any engine codes? if so what are they.. could be the ignition switch, if you
have a rubber mallet gently tap the key if it starts then i would say ignition switch ,if it frees up the key same thing
Old Jan 20, 2015 | 07:39 AM
Hags72's Avatar
I have since changed the ignition switch still no crank. key still will not come out unless I press the release. Anyone?
Buddykitchen
Dec 10, 2016 06:37 PM
princered72
Jan 14, 2015 06:27 AM
Travis West
Dec 31, 2012 12:54 PM
g_mike
Aug 22, 2010 02:46 PM
LowLife
Jan 24, 2010 11:57 AM
