1998 Blazer - Sluggish and switches between 3-4
Old Jun 25, 2012 | 11:34 AM
Fireworks's Avatar
Fireworks is on a distinguished road
Default 1998 Blazer - Sluggish and switches between 3-4
I just recently acquired my 1998 blazer and it seems to have very slow acceleration. I have to really put the pedal down further than I'd like to just keep up with anyone at a stop light. It also has a hard time going any better than 60 or 65.
On another note, at around 40-45 mph it will shift back and forth between 3-4 gears. This happens for as long as I hold that speed. If I am pressing a little harder and just power through that zone it seems like it doesn't get a chance to flip back and forth.
I did check out the 4L60E common problems thread and it didn't seem to cover my issues because I have full use of all 4 gears and reverse.
Thank you in advance for your help!
Old Jun 26, 2012 | 01:35 AM
Fireworks's Avatar
Any help would be appreciated
Old Jun 26, 2012 | 01:38 AM
50lb_cat's Avatar
Have you checked the fluid level? How is the fluid color and smell? It sounds like it may be an electrical issue though.
Old Jun 26, 2012 | 01:40 AM
Fireworks's Avatar
K Stupid question, but where is it? I've found every other fluid but the tran fluid...
Old Jun 26, 2012 | 01:44 AM
50lb_cat's Avatar
Its a locking dipstick, its been awhile since I looked at it but its to the left of the plenum (passenger side) and it might be colored.
Old Jun 26, 2012 | 01:46 AM
Fireworks's Avatar
K thanks! I'll def try and check on it tomorrow after my morning drive.
Old Jun 26, 2012 | 02:02 AM
50lb_cat's Avatar
Its best to check warm anyway. I will have to do some digging. I remember another member having some tranny issues but turned out to be an electrical gremlin.
Old Jun 26, 2012 | 05:13 PM
Fireworks's Avatar
Ok I checked the fluid and it's red and seems to be the right amount. However a new symptom occurred. It decided when I put it in reverse that it preferred neutral instead. So I put it back in park and then back in reverse and it worked fine. But this is the second time in a week that it's done that.
Once again, thanks for your help!
Anyone have any helpful suggestions?
Old Jun 27, 2012 | 12:52 AM
50lb_cat's Avatar
Hate to say it but it sounds like the tranny is sliping and it may need to be rebuilt.
Old Jun 27, 2012 | 06:37 AM
Fireworks's Avatar
Is it possible that it could be solenoids going bad or is it more likely that it needs rebuilt?
