1998 Blazer - Sluggish and switches between 3-4
Old Jun 27, 2012 | 08:23 AM
50lb_cat's Avatar
Its possible that's all it is, but it also kind of sounds like the sun shell is failing. I would look online or ask around for a trustworthy tranny shop and have them look at it.
Old Jun 27, 2012 | 01:58 PM
aa21830's Avatar
aa21830 is on a distinguished road
Originally Posted by Fireworks
On another note, at around 40-45 mph it will shift back and forth between 3-4 gears. This happens for as long as I hold that speed.
Is it truly shifting back and forth between 3 and 4, or are you in 4 and the torque converter is locking and unlocking? That is somewhat common; sometimes caused by a bad TCC solenoid. Other than the sluggishness, I had similar problems. Tranny flush and new filter fixed it. Never have figured out why.
Old Jun 28, 2012 | 08:50 AM
Fireworks's Avatar
Fireworks is on a distinguished road
It honestly feels like the torque converter keeps engaging and disengaging 4th. But would that also have difficulty engaging Reverse every once in a while? It's done that a couple times for me now. I'll put it in reverse and it acts like neutral, then I put it back in Park and back to Reverse and it pops right back in.
I really appreciate it
Old Jun 28, 2012 | 12:07 PM
aa21830's Avatar
At the same time I had the TCC lockup issues, I had that same problem with reverse. Sometimes it would clank and try to "grab" reverse, but only when the tranny was cold. Also at that same time, I didn't realize that my input seal on the transfer case was letting tranny fluid into the transfer case. So my tranny fluid level was gradually dropping, which may have contributed to at least some of this. But I've never understood why, after 2 simple tranny fluid/filter changes (about 30k miles apart), everything suddenly started working perfectly. Has been for almost 3 years now.
Old Jun 28, 2012 | 01:32 PM
Fireworks's Avatar
K well mine doesn't even try to grab, it just disengages the park and does nothing, no grab no clank etc.
kennyking927
Aug 29, 2014 12:17 AM
chris015
Apr 5, 2012 06:00 PM
peterlucas
Dec 16, 2011 03:15 PM
96jimmyslt4x4
Jul 25, 2011 10:18 PM
hardyboy
Mar 23, 2011 08:04 PM
